A young talent at work.
I hadn't seen this image until yesterday. Just thought I would post it. Big block Hudson also.
Am I the only one who is seeing a bunch of computer code, and not a photo?
Nope, that's all I get as well.0
Because , as I said in my previous posts, at the moment the attachment code isn't working. I've had to concentrate on the main site and its ancillary bits, now I can start to look at migrating the Open Forum to a different home within Amazon that allows PHP for this site to play nicely ...0
Now fixed as you can see (I hope)0
Yep. Pic worx for me.
Thanks for keeping het running smooth0 -
Is that a ratchet or a torque wrench he's using? Wonder if the head was being torqued to the usual 65 lbs. or perhaps higher as I gather that Hudson six would have seen some serious use in a little while.
Paul, you are working like a dog, patching this system together after the big move! Thanks again for all you do for the Club!0
you do notice the pipe and white uniform don,t you?? !!Smokey!!!0
Dial torque wrench.
Thank you Paul.0
That man made Hudsons run fast in NASCAR, Smokey Yunick.0
