A young talent at work.
didusay39
edited December 2018 in HUDSON
I hadn't seen this image until yesterday. Just thought I would post it. Big block Hudson also.
  • Am I the only one who is seeing a bunch of computer code, and not a photo?
  • Nope, that's all I get as well.
  • Because , as I said in my previous posts, at the moment the attachment code isn't working. I've had to concentrate on the main site and its ancillary bits, now I can start to look at migrating the Open Forum to a different home within Amazon that allows PHP for this site to play nicely ...
  • Now fixed as you can see (I hope)
  • Yep. Pic worx for me.
    Thanks for keeping het running smooth
  • Is that a ratchet or a torque wrench he's using? Wonder if the head was being torqued to the usual 65 lbs. or perhaps higher as I gather that Hudson six would have seen some serious use in a little while.
  • Paul, you are working like a dog, patching this system together after the big move! Thanks again for all you do for the Club!
  • you do notice the pipe and white uniform don,t you?? !!Smokey!!!
  • Dial torque wrench.
  • Thank you Paul.
  • That man made Hudsons run fast in NASCAR, Smokey Yunick.
