Fan Belt for a 308 Engine
The 1946 Hudson Super Six convertible I've been working on for a few years needs a fan belt for its 308 engine. It currently has a Gates Green Stripe 669 belt. The belt seems to sit a little deep in the pulleys and has some edge wear as a result. Does anyone have a suggestion for a better fitting belt? Thanks, any help much appreciated.
This is the current belt.0 -
You need a B section belt. If the current belt is sitting low in the pulleys it could be a narrower A section belt. As a work around its OK so long as its not bottoming on any of the pulleys.0
We used a bar of soap to stop it from slipping
Just my two cents0 -
My parts list shows NAPA 349 Check it out
Thanks Uncle Josh. The specs on this belt are very close to what I physically measured with a tape on the Gates 669. I'm sure it will work.0
- 112 Hudson 1916 - 1929
