1932 Hudson Sterling
WANTED  4 motor mounts ,is the Metro MM 7-C the right one Thanks Ron
  • you need an MM 7-B and an MM 7-C per side for front engine mounts. Four pieces total.
  • This is for 1930-1933 Hudson.  Metro shows nothing for these models.
  • Fresh search this A.M came up with MM-7C which is correct for your car.
  • 54coupe   Is there a WWW that shows the mounts Thanks Ron
  • Oops, maybe not, dimensions don't look big enough.  I installed mine in 1968. Not sure of measurements.  Sorry for  the confusion.
  • 1954Hudson
    edited February 2019
    No confusion  is there a www that shows the mounts,what is MM7-B ?
  • MM-7 B and C are the top and bottom mounts for the front of 32/33 Terraplane as well as 34-47 Hudson engine.  Much different than your 32 Hudson. I could try to get pic of my 32, if that would help.
    Fred
  • Just a thought: have you spoken to any other 1932 owners to see what they've used?  Possibly someone has discovered an interchange with a much more popular (read that: obtainable) motor mount.  Or a source of an actual reproduction or original one.  Or maybe through some miracle, they have a spare one they'd sell you.
  • Thanks Jon
  • Then & Now Automotive in Weymouth MA rebuilds motor mounts as well as fuel pumps. They have a web site.
  • I have NO motor mounts to rebuild Thanks
  • Check with Carl Weber or Del Fast both are listed in HET Roster and WTN.  Both have cars of those years.
