1932 Hudson Sterling
1954Hudson
WANTED 4 motor mounts ,is the Metro MM 7-C the right one Thanks Ron
you need an MM 7-B and an MM 7-C per side for front engine mounts. Four pieces total.0
This is for 1930-1933 Hudson. Metro shows nothing for these models.0
Fresh search this A.M came up with MM-7C which is correct for your car.0
54coupe Is there a WWW that shows the mounts Thanks Ron0
Oops, maybe not, dimensions don't look big enough. I installed mine in 1968. Not sure of measurements. Sorry for the confusion.0
No confusion is there a www that shows the mounts,what is MM7-B ?0
MM-7 B and C are the top and bottom mounts for the front of 32/33 Terraplane as well as 34-47 Hudson engine. Much different than your 32 Hudson. I could try to get pic of my 32, if that would help.
Fred
Just a thought: have you spoken to any other 1932 owners to see what they've used? Possibly someone has discovered an interchange with a much more popular (read that: obtainable) motor mount. Or a source of an actual reproduction or original one. Or maybe through some miracle, they have a spare one they'd sell you.
Thanks Jon0
Then & Now Automotive in Weymouth MA rebuilds motor mounts as well as fuel pumps. They have a web site.0
I have NO motor mounts to rebuild Thanks0
Check with Carl Weber or Del Fast both are listed in HET Roster and WTN. Both have cars of those years.0
- 173 The Flathead Forum
- 599 Vehicles
