37 terraplane power brake conversion
getley
in Street Rods
has any one put a Power brake unit in a 37 Hudson terraplane with drums all Around? If you did what did you use and what did you need to adjust to get it in
I put a GM Firewall Power Booster on my '37 with a Swing Pedal with 4wheel Drums. However, I upgraded the small '37 brakes with large Hornet 11x 2 1/4" Brakes which practically interchange. It may benefit you to install large Hornet/Commodore Brakes instead of a Booster....
The Booster & Swing Pedal was easy by figuring the location snd make a Template of bolt pattern. Drill 4 holes then hole saw a center hole for the Pushrod, then bolt the two halfs together (Booster outside firewall & Swing pedal Inside). The firewall is strong but I added a short brace above the pedal assy too. I was going to put Discs on but it stops so well that I scrapped that idea.....0 -
Thanks, Looking into now.
Send pictures0
getley said:has any one put a Power brake unit in a 37 Hudson terraplane with drums all Around? If you did what did you use and what did you need to adjust to get it in
The mounting as described above and a couple plumbing changes were very easy and produced outstanding results. Very worthwhile upgrade.0 -
Ol Racer, what a great picture! I wanna visit your garage.0
keithfullmeryahoocom said:Ol Racer, what a great picture! I wanna visit your garage.
- 110 Hudson 1916 - 1929
- 177 The Flathead Forum
