wtb parts for a 1933 Terraplane 8 cyl. 2 Door Coach
I am rebuilding the chassis on my 33 Terraplane. The body is done, but I need to finish the chassis and get it back on the road.
I need a differential pinion seal and grease seals, also king pins & Tie rod ends for the front end.
Also my 8 cylinder block is cracked - if anyone knows where there is a good 33 T 8 cyl. block please get back to me. 815 440 8887 or jeanblanc1952@yahoo.com Thanks Chuck
There is a pinion seal on Ebay now
Listed for a 1032 Terraplane
My interchange lists it for 1932 only
perhaps others have more info:
It is not mine and seems expensive
Nice talking to you
sure glad you found the 1933 seal a few lines down !0 -
Hi Ted here. There is a fello near Ottawa Ontario Canada . That has a turning rebuildable 33 t8 engine. He got it out of a us 33 car. Engine is complete . I would like the water pump off it. He is asking to much for it. If ur Us ur exchange is in ur favor. .70 to our dollar.. eddy is his name. 613 552 6224. Or 6138839932.0
U can also use a 34/35 Hudson 8cyl. A little more cubes with ur 33 pump and pullies0
Hotrod2591 could you make a pattern of one of your door glass. I’m needing to complete glass install. Out of paper would be fine and I’ll compensate.0
- 111 Hudson 1916 - 1929
- 570 "How To" - Skills, mechanical and other wise
