Grease to be used for my 1941 hudson
BernieBuechman
I have read in the original 1941 Hudson manual it calls for a aluminum soap based grease for use for spots such as the water pump. My question is can you buy a product in 2019 which would be compatible or better than the original grease called for my car.
Thankyou Bernie
Thankyou Bernie
Hi I found the radiator grease quite hard to find but penrite oils in Australia sell it. They have a few retailers selling it so I found a auto shop close by and bought 2 tins. You could also use a grease used in the food manufacting industry for lube jobs0
You might try a water-resistant grease.
Here's one recommended by Mac's, which sells parts for Model-T Fords: https://www.macsautoparts.com/ford_model_t/water-pump-grease-14-oz-cartridge-multipurpose-lubricant.html?utm_source=google&utm_medium=paid_search&utm_campaign=paid_search_google_pla&adpos=1o4&scid=scplp16-50762-1&sc_intid=16-50762-1&gclid=EAIaIQobChMIhZO_37Le4QIVTwOGCh0aswYyEAQYBCABEgLo9_D_BwE&gclsrc=aw.ds
Lubriplate 115 is a good water pump grease (or so says Lubriplate!): https://www.lubriplate.com/Products/Grease/Multi-Purpose-Greases/100-Series/NO-115/No-115-Water-Pump-Lubricant-16-oz-Tub/ You can buy it direct, or Google it; I understand that Restoration Supply may carry it. It's in a tub, so you will have to buy an empty grease gun and pack the Lubriplate into it.
Amazon (and probably other places) sell this aluminum-based marine grease. It doesn't say "for water pumps" as Lubriplate does, but might work: https://www.amazon.com/Sta-Lube-Marine-Trailer-Bearings-14-Ounce/dp/B000KKLLPS/ref=asc_df_B000KKLLPS/?tag=hyprod-20&linkCode=df0&hvadid=312151168520&hvpos=1o4&hvnetw=g&hvrand=12223750684533013257&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9007592&hvtargid=pla-492477188761&psc=1
Actually, any boat trailer wheel bearing grease might work.
