Wheel & master cyl. for '54 Hornet?
A fellow in our chapter has a '54 Hornet. Needs master cyl. and all 4 wheel cylinders.
Anyone know if local parts houses (NAPA, AutoZone, etc.) would be able to get this stuff in overnight (as they did for my Terraplane!)?
If not, I'm sure our trusty Hudson vendors will have what he needs. I just thought I'd first look to see if it's available locally, so he could get started.
I know this has been discussed a thousand times on the Forum but (being a Terraplane owner) I'm afraid I didn't pay attention when maybe I should have.
NAPAPart #s not for Pacemakers, Jets.Master Cylinder (48-54 Hudson)M3081Front Wheel Cylinder (Left, 48-54 Hudson)18290Front Wheel Cylinder (Right, 48-54 Hudson)18291Rear Wheel Cylinder (Left, 40-54 Hudson)370192Rear Wheel Cylinder (Right , 40-54 Hudson)370193Brake Hose (Front and Rear, need 3 total)11149Might as well replace:Brake Light Stop SwitchECH SL 134The only goofy thing regarding the brake cylinders is that the bleeder screw is metric. Everything bolts up and functions fine. These part numbers are listed in the 2018 Jan. WTN.Good luck.
Thank you very much! I'll send this off to our chapter member immediately!0
Hey Glowplug:
An extra-big THANKS from our local chapter member.
I sent your specifications to the chapter member and he responded that he didn't need them now that he'd found a parts company to send him the master and wheel cylinders by mail.
Turns out they sent him 4 MASTER cylinders! When asked, they responded they didn't carry the wheel cylinders.
So the chapter member's mechanic tried the local NAPA for the wheel cylinders, using the car's year and make. "We don't sell those", came the reply.
He then gave them YOUR parts numbers. Turns out the cylinders were sitting on their shelf.
