Flexplate 308
URGENT,need an new flexplate to a 308
  • You mean flywheel?
  • nope,flexplate.its destroyed by the starter
  • Wikipedia says: "A flexplate is a metal disk that connects the output from an engine to the input of a torque converter in a car equipped with an automatic transmission. It takes the place of the flywheel found in a conventional manual transmission setup."
    But weren't two different automatic transmissions used over the years on a 308, the Hydramatic and the Borg-Warner?  I guess you would need to specify what year.
  • toresine
    edited May 2019
    hydramatic on this one,1952
  • Hudson parts book calls it  Flywheel assembly for HT transmission.  Also called torus cover. Flex plate is a more recent term for the plate joining the engine to ta torque converter.
  • never mind the terminology,I NEED THAT B----- PLATE
  • I have Hydramatic flywheels if that is what you need. It bolts to the crankshaft and the Hydramatic torus.
  • Lance,please PM me
  • Done.
