Seeking sway bar end links....
You might want to publish a photo of the actual links and bushings (from the parts book?). It's possible that some Hudson vendor actually has these, but not in the box, so he doesn't know what he has.0
Good idea, thanks Jon!
Here's some pics of what I am looking for.
They measure 12" long and are 3/8" in diameter.
Thanks!
Jeff
These are on Doug’s website0 -
Shock absorber mount bushes will work on the bottom end. The top end is a ball and cup and spring arrangement similar to those on the ends of the drag link?0
Hey Bob,
Actually it seems to have been two rubber bushings that fit inside to cushion a flat spot on the end of the sway bar.
Any leads out there?
Jeff
