Top 5 Fastest Hudson’s?
As I was talking with a friend about his Bonneville records in a 27 Dodge & it got me thinking about what Hudson’s might be the fastest cars made? 0 to 60 times & top speed would be interesting to know. I remember reading about a Hudson around 30-32 that was under 7 second 0-60 car, but I’m not 100% on that.
From Hemmings:
“Mechanix Illustrated tested a Twin H-Powered Hornet in 1952 and recorded a 0-60 mph time of 12.1 seconds and a top speed of 107 mph”0 -
From allpar.com:
The 1938 Hudson Eight did 0-60 in 15.0 secs
“The 1933 Essex Terraplane Eight was the car that really made Hudson company’s performance image. It was the original factory hot-rod sedan with 0-60 mph in 14.4 secs, top speed 85 mph.”
From WikiVisual.com:
“Two special (1935 Railton 8) lightweight models were made in 1935 and, with a 0–60 time of 8.8 seconds, were claimed to be the fastest production cars in the world.”0 -
My friends Bonneville Record Holding Car:
Haha hahaha, nope I believe it’s a 27 Dodge but then I’m not sure it looks like that either!
I believe their National record in 2016 was 147 mph. Crazy fast for that original 4 cylinder, which is well massaged!0 -
1928 Dodge fast four.
Correction:
1928 Dodge Brothers Victory Six Roadster
I knew of these guys when I lived in Seattle. I contacted them and asked if they would be interested in bringing a Hudson powered Bonneville car, they brought the Hudson powered (308) streamliner to a car show. It really drew a crowd even when it wasn't running. http://hudsonboys.com
The 1934 Railton Light Sports Tourer lapped Brooklands at around 115mph a number of times pre-war. The axle ratio would have been either 3.3 or 3.5.
The 1937 Hudson Eight sedan averaged almost 89mph at Bonneville back in the day for the 24 hour run. I suspect it may have had a taller axle ratio, ie taller than the standard 4.1. That's a fantastic result. The Hudson Six was only just behind it too in terms of average speed by a couple of miles per hour showing how good the 212 was. Considering it was 15% or so less displacement.0 -
122.683 on the Bonneville Salt Flats 1980......
That is a 4 cyl Plymouth block. I am working on one as we speak,...mine will not likely be powering a Bonneville contender, but I hope to up the output a bit from it's original 56 horsepower.
Dave0 -
The Hudson Boys, out of Seattle, (I think) have a Hornet powered streamliner. It set a record for a supercharged flathead streamliner less than 325 cubic inches at over 250 MPH. The record was set in 2002, and as of last year,still stands.0
