46. 254 rotor
paulrhd29nz
Does any one have a Napa part number for the rotor?
I don't know if this will help, but I have an old January, 1958 NAPA catalog and it shows under Hudson distributor rotors: "All 8 cyl. (exc. Hornet 50) … 37-47 Echlin AL-46 suggest retail price .62"0
I have those rotors. I think NAPA may have discontinued those numbers don't know for certain0
This is what I have listed for my 1937 254 engine, you’ll have to see if it may work.
Rotor: Standard Motor Parts AL-102 (AL64??), NAPA AL32.
Don't see any of the correct parts here. OEM number was IG 1325 none of those are the correct style. The rotor for the 48-52 254 was similar but was not the same as the earlier 8 cylinder version.0
It’s probably the best thing to order those from Wildrick Restoration. This maybe the items, but call & talk to Cole there, he’ll fix ya up.
https://www.wrphet.com/engine.html
Railknight I have those if you are interested.0
Thanks everyone. I’ll be calling you Lance0
I found my Hudson Swap Manuel and parts interchange book. It list my cap and rotor as
AL59 and AL58 for 35-47 8cyl.0 -
Paul my number is 704 792 911 zero.0
Rotor 254 eightStandardAL99DelcoE739A
