Door weatherstripping pictures needed
I am working on putting the door weatherstripping in on a 1949 coupe. Can someone post pictures of the weather stripping correctly installed?
I have what I believe is the correct parts from WRP but want to make sure I install it correctly.
My area of question is mainly the door jam with the S piece and what else is needed up and down from there.
Thanks,
Thanks,
Go to my website and select : https://hudsonrestoration1948-54.com
Select body work and trim - middle of page complete write up with pictures. Same for coupe or sedan.
Perfect, thanks!
I also found where those windshield drain tubes go....from using your website!
thank you very much.
