1941 hudson repairs axle and pinion
I was just curious what the cost would be for a inner and outer axle seal and a pinion seal. Just a aprox, idea on the cost and or time to do this job.
Thanks Bernie
Thanks Bernie
Flat rate manual for Step-downs would be exactly same as '41: Drive pinion oil seal remove and install 1.1hrs. Axle shaft inner oil seal, remove and install, both sides 2 hrs Axle shaft outer seal, both sides, 1.7 hrs. You can at least double those times for extra work like cleaning and painting, de-rusting, etc.
I have a deluxe six 1941 will a inner seal od 70 mm-35mm-od by 7 mm thick work I hate to get at it and find that the seal is not right for my car.
Thanks Bernie
- 111 Hudson 1916 - 1929
- 570 "How To" - Skills, mechanical and other wise
