1929 Essex
1929 Essex do have to prime oil pump after changing oil
  • ernie28
    edited June 2019
    No you shouldn't need to. I never have on any year Essex  I have had. The only time you may need to is if you drop the oil pan. Even then unlikely.
  • I did drop the oil pan
  • No, you should not need to  prime the pump unless you have removed and dismantled it.
  • Cleaned the oil pump an all is well
