1929 Essex
how to prime the oil pump on 1929 Essex
You can call 906-869-31800
it’s still on the block I will remove the cover look at the spring,piston,spring an cap valve. Yes I filled the dipper tray an new gaskets. Thanks for the information. dose the distributor drive have to be filled with oil to prime the pump0
