1929 Essex
jmin
1929 Essex do have to prime oil pump after changing oil
No you shouldn't need to. I never have on any year Essex I have had. The only time you may need to is if you drop the oil pan. Even then unlikely.0
I did drop the oil pan0
No, you should not need to prime the pump unless you have removed and dismantled it.0
Cleaned the oil pump an all is well0
- 115 Hudson 1916 - 1929
