Air cleaner for 262 w Supermatic
cheyenne7271
Does anyone have a correct oil bath air cleaner for 50 Super 6 262 2bbl for the Supermatic setup? The only difference I see is the vacuum or air intake port that the system connects too on the bottom of the air cleaner. Thank you
I'd settle for a photo of the vacuum connection so could make my own! Any one got a photo to share?
I have the filter off of me 50 Pacemaker Deluxe 232 with the Supermatic.Here are pictures of it.The fitting on top went to a Reclaimo Filter.Larry0
Thanks Ducor, what does that lower fitting do? Does it act as a vent for the system?0
I believe you are right. It looks like it just provides a clean air source to Supermatic.
Ok that makes sense, but if you or anyone knows of a correct unit, I’ll take it. My Super is an all original 16k mile car that I’m trying to preserve, everything is intact and working except the drive master part of all of this.0
Yes, thanks for the photos. This is a big help to me to know what that fitting on the bottom looks like, and where it is situated!0
