Looking for NOS front wheel bearings , inner& outer both sides & seals 1951
supersix
Does anyone know where I can find front wheel bearings and seals or part numbers so I can go to my local Napa ? Thanks,Dave
If you have a good NAPA store that has the old books they should be able to look it up.0
The old bearings will have part numbers on them. The seal, you won't find at NAPA, they don't make seals like that these days...find one of the Hudson parts places to get them.Or do like I did and just reuse all the parts, they will probably work fine. Unless you know for sure there's something wrong with them (but if you did, that means you would have inspected them, and seen the part numbers on them)0
You will have a more certain outcome if you take the bearings into a proper bearing and seal store rather than a car parts place, the bearing shop is used to helping people who walk in with parts in hand
The bearings are not Hudson specials they should be off the shelf, seals can be a little trickier sometimes. If the 1/4" thick single lip seals are not available there is a work around using thicker double lip seals.0 -
Bearings, Front WheelTimken, etcCone38-47Inner15118Outer9078Bearings, Front WheelTimken, etcCup38-47Inner15250Outer9195Bearings, Front WheelTimken, etcCone48-54Inner15123Outer9067Bearings, Front WheelTimken, etcCup48-54Inner15245Outer9195Seals, Front WheelTCM15625236-54 x JetChicago RawhideCR15649National6407NAPA16246
Thanks Larry0
Unc comes through again!
Wow ! Thank you , Dave0
I believe Dr Doug sells the complete sets on his website
www.wrphet.com
And if you only need one or two I believe they are available on Rockauto.com and will cross to a Timkin bearing and race.
Jeff
Thank you.0
- 97 Essex Super 6
