Late Model Mustang Wheels on a 1936 Terraplane
Rocket88
Has anyone put 2018 era Ford Mustang Aluminum wheels on a 1936 Terraplane (Front Axle) ? Or any late model Ford Aluminum wheels?
If so, two questions: Is there clearance inside with the tie rods etc, and is the center hole of the wheel large enough to clear the Hudson wheel bearing housing?
Thanks in advance
Thanks in advance
I suggest measure your wheel Offset and the diameter of your hub then go to the Savage Yard and compare measurement's. Ive put 15" Vintage Mopar Mags on my '37 with no problem and they are 3 1/2" offset (Back spacing).
Thanks!
- 579 "How To" - Skills, mechanical and other wise
