Need intake manifold 308
I have a 1951 308 6 cyl and need a used aluminum intake manifold that will be modified to run three Holley 1904 glass bowl 1 barrel carbs. I am putting the engine together to run at The Race of Gentlemen in Wildwood NJ. Also any suggestions on a good cam would be appreciated. This car will be run on the street also not just race. Thank you Warren
Does anyone know who makes the side draft webber manifolds? I could modify a set of those to work buy building a log intake that bolts to them.0
Thank you 54 coupe I will give them a call
