Gas millage
enjoy the drive!0
Are you sure your odometer is correct? Have you tested it (by comparing the odometer readings to the mileposts on your nearest Interstate highway)? I would try verifying that for starters, so you're sure you're dealing with the right numbers.0
I have gotten as high as 18, and most often 16 on my '50 C8 3spd w/ OD (Supermatic rear), 12 seems a bit low to me.0
I will check my odometer. thanks
- 110 Hudson 1916 - 1929
- 177 The Flathead Forum
