Beautiful 1950 Twin H Commodore Coupe up for auction
SwampyMeadows
nice looking 50. It could go for a reasonable price on BAT.
Can any Twin H experts chime in on this situation brought up in the comments section:
With no reinforcement rib, it is NOT a 308 block. Which means it’s either a stock 232 or 262 block, with a 308 head which would lower compression considerably, or it’s been bored out to 308 specs. However, without the reinforcements that a 308 block has, it’s a catastrophic failure waiting to happen. True factory 7X motors were 308 blocks with 232 heads (for better compression). This engine seems literally the opposite?
Need to see the rest of the block casting number. The block is NOT a 308. The casting number for the 262/232 (yes they are the same block) is 310110. This block was cast in
Muskegon MI by Lakey steel foundry,0 -
This subject was well covered in the facebook page sections. It is clearly not a 308 engine. The machining modifications are not discussed but with minor work a 262/232 engine can give excellent performance. Other than the fact that this car is misrepresented by the facts, it could be a very nice car to have. I would be a "byer beware" customer, but I would consider it at a good price after you cut through the hype?
- 96 Essex Super 6
