308 Twin H Exhaust manifold needed
Mine broke yesterday...anyone have one? the catch is I need it soon, planning to leave on a trip Friday.
I'm in southeast Arizona, 520 456 648
Thanks,
Jim
  • I put in a call to Al, but last time I called him it took two weeks for him to get back. Mine has the cast balance passage...I guess I need to do some more research on this!
    Thanks for the quick reply. I'll send a PM
  • Did you find a Manifold? Enjoying your trip?
    I put Twin H on my 52 and used the single carb exhaust manifold.
    If I remember correctly , I drilled the manifold and used an AMC choke pipe.
    You could put a T fitting in the heat tube for both carbs.
    I don't know of any other difference.
  • HI, I did find a manifold today, thanks for asking! I got ahold of Al, and went up and got the only one he had. I'm working on installing it now.
    It's a 55-56 manifold set, which makes it more interesting, I guess.
  • Yes , the exhaust pipe is at a different angle. Nothing you can't handle.
    The throttle linkage may need adapting?
    I had a 56 engine in my 52 hornet , but it was years ago.
    Hope you get it done in time.
    Have fun
  • The manifolds on my car were already 55-56 setup, I just got an unbroken one to replace the broken exhaust manifold. No changes required.
