51 Commodore suspension upgrades?
Just started work on my new toy. It needed everything in the brake system. It still has the original shocks & sway bar links. Everything went fine until I broke the rear brake line at the master cylinder.
Does anyone know of a larger sway bar that will fit?
Is there a rear sway bar that will work?
Any suggestions on shocks?
Give Dale Cooper (Hudsonmotorcars.com) a call for the front sway bar. He has a wait list for the next shipment.
Joe
Back in 1990 I adapted a 1 1/8" sway bar from a Jeep on to my 52 Wasp. What a difference!0
FYI, the correct URL for Dale's site is: https://www.hudsonmotorcarco.com/welcome.htm0
54 coupeCan you tell me what Jeep your bar came from?0
1990 Cherokee. It's a little too narrow where the end links mount. I heated it up, about 4-5 inches from each end and bent it outward then let it cool on its own. I used the factory, 3/4" bar as a guide. I have done a couple of them over the years. A used one from a salvage yard is less than $30.0
