Throttle return spring
In particular, Grim Greaser has a dual spring on his project engine that appears to be what is needed, but I don't see those in stock online with the usual car parts stores...0
I'm not entirely sure where I picked up the spring... Gotta be one from the parts store performance section... I did drill and tap the block next to the serial# for the anchor though.0
Those springs are on most q-jet carbs from factory. More than likely found at Summit or Speedway or local parts store universal stock displays.0
- 96 Essex Super 6
