49 3 speed transmission parts
I have a Hudson built transmission; the "R" transmission. I think they were all the same from 41 to 50 or 51. I need the following parts so if someone can direct me that would be a big help.
1. Cluster gear, the large end has 26 teeth and the part number is: 166203
2. The sliding 1st and reverse gears, part number 305091
Thank you,
Marvin
Al Saffrahn in AZ.
Great guy!
Jeff
I have a 49 3 speed trans still in a 49 Commodore 6. Parting out the car. What's it worth?0
jjbubaboy thanks for the referral. TerraplaneCoupe I'm not looking for a transmission just the gears I listed. If you had your apart and knew the gears were in good condition, then I might be interested in talking about it.Thanks guys,0
