splasher oil pan screen
dantheman
My 36T oil pan has a section of the oil screen missing at the bottom of the pan. Where can I get some. I assume it would have to be soldered in place?
Honestly, I’d consider something along the line of a trap door baffle system, if it’s feasible. I’m just starting to look into this for my pan to ideally prevent starvation as oil sloshes around or I hit a steep hill or take her over a mountain pass after she’s all back together.
Heres a video on it:
https://youtu.be/8eapLmnkErQ
On the factory pan, here is a couple pictures of my pan. Mine looks like it’s a copper mesh material & just has some tack welds to hold it in place. Hopefully you can see those in the picture. If you have yours in hand, try searching on line or hit a hardware store or even an auto parts store as they may have something they remember from a totally different application which may work. Heck you could even look at a cooking or beer supply house as they may have something to work.
Yeah mine looks like yours except one of the squares is missing. I guess it would have to be a good grade of screen to be able to solder it in. i thought maybe someone had this problem and had a source for screen material.0
Try McMaster Carr. Type in the search filed copper screen. They have many mesh sizes and you can get a one foot square piece relatively inexpensive0
G'day Big Sky
looks like that sump has been sand / media blasted
Beware of trace grit. Blasting the sump with all of that mesh and opportunity for residual media to remain is something i would not risk.
Take care to clean it well
phil0 -
Thanks for the McMaster Carr tip. Great web site! Not only found the screen but also some studs and nuts I've been looking for!0
