51 Pacemaker Resurrection
RPM is usually what kills connecting rods (it tears the big end apart), although if you make enough power, you can buckle one.0
squirrel said:RPM is usually what kills connecting rods (it tears the big end apart), although if you make enough power, you can buckle one.
PS - I cuisinarted my first rod at 12. It was a shock to pull the head off and look at the crank journal. I remember looking up at the sky, thinking it magically escaped the motor somehow. It didn't - I found it and the remnants of the piston in the pan.
Ken U-Tx said:squirrel said:RPM is usually what kills connecting rods (it tears the big end apart), although if you make enough power, you can buckle one.That's part of the story......piston weight and piston speed in feet per minute is also a very significant factor. The 4.5" stroke 308 has a average piston speed of 3,375 feet per minute whereas the 3.875" stroke 232 has an average piston speed of 2,906 feet per minute. The reason I say "average piston speed" is because the speed of the piston is not constant throughout the stroke, it is rapidly accelerating to even higher feet per minute speeds and then rapidly decelerating to a stop before reversing direction in the reciprocating cycle. The resulting G forces on the piston and rod assembly's mass puts tremendous pressure on the big end and rod bearings that is born by a thin layer of oil. It is therefore easy to see the importance of using as light a piston as can be used without having issues (piston slap from too short a skirt length, etc). Rod bolts can stretch under high loads, and this naturally can result in the bolts failing and then the rod coming loose, usually beating an exit through the cam side of the block. On the 262 and 308, you should be gearing the car to keep the rpms in the peak torque range at the speeds you want to cruise in. Gear them down, not rev them up.
All my performance engines receive ARP bolts and studs. I've seen high speed film of rotating elements as part of my dyno work with GM, and it is amazing to see how much components move in operation.
Ken U-Tx said:I neglected to state that the average piston speeds stated above were for 4500 rpm. I do know that destructive harmonic resonance sets in at the 4800-5000 rpm band on the stock 308 crank......In real world driving, you should never have to exceed 4000 rpm with a 308. 4000 rpm with a Hydramatic and 3.07 Dana 44 will give about 110 mph.
The harmonic resonance speed is good to know as well, thanks!
- 110 Hudson 1916 - 1929
- 177 The Flathead Forum
