Headlight Conversion Options
I'm not a young man anymore. My arms have gotten too short to hold a factory service manual far enough away for me to see the print clearly. To be able to work on a car in the garage/shop, I had to double the amount of lighting recently. Additionally, I live in the mountains, and all matter of critters love to jump out in front of the car in the middle of the night.
I want to see them!
Original style sealed beams are fine for a 19 year old who can spot a girl a half mile away in moonlight, but for us old guys, we need all the light we can get. Pops' solution on his Model A was a set of 12V tractor lights clamped to the bumper mounts, driven by a 12V battery. It works, but it looks odd and the cost of the lights, mounting hardware and battery are expensive. Of course, the car can be changed out to 12V, but there's something about the "rump-rump-rump" of a 6V starter that well, sparks joy.
Now I'm sure a bunch of guys already know this stuff, but there are many ways to adapt modern technology to help see with a 6V system - or to improve vision with a 12V system. The first step is to get a pair of conversion lamps. These look like sealed beams, but the reflector is configured to accept a modern halogen insert lamp. The cost range is from $15-$35, with the more expensive brand name lenses closer to an original lens pattern.
Now - if you're running a generator (and I like generators; when they go bad, you can fix them on the side of the road with $15 worth of brushes) you have the power output of a mason jar of fireflies. What guys with modern classics and 12 systems do is pop in a high wattage (80-100) watt halogen and light up the night. I had a four headlight factory system like this on my Bentley, and the light range was an honest two miles. Unfortunately, the current draw of a pair of big halogen lamps may exceed the generator's capacity, especially if the system has increased resistance due to corrosion and age.
A better solution is a pair of 6V LED headlight lamps. Most moderns these days run LED's, and with the conversion headlights in place, the LED lamps pop right in like a halogen. Wattage is less than half that of the incandescent lamp - with greater light output!
With a pair of conversion headlights and LED lamps as shown above, you've a much brighter view of the world for $60 which looks very traditional - until you turn them on. With lest load on the generator, you won't get the headlight dimming effect at idle that generator cars have, either. I have to do a bit more research on LED tail lamps and turn signals, as the reduced wattage affects the blinker relay.
Hope this helps some folks!
I want to see them!
Thanks, very en'lightening'.
Not sure if this offers anything significantly different or better; these guys have bulbs that work on 6 or 12 volt, generator or alternator, etc. I have a pair, but have not put them on the car yet. http://www.logolites.com/products/led-headlights/0
chucksherman, thank you for this information. I agree, I need brighter/better headlights and this will come in handy.
I have used the Rampage conversion on my Jeep Wrangler. They are 12 volt, but it was a huge improvement over the seal beam lights.
https://www.autozone.com/collision-body-parts-and-hardware/headlight-assembly/rampage-headlight-assembly-5089925/375860_742130_0
There are several threads on this.
https://openforum.hetclub.org/discussion/172298/possible-alternative-for-hudson-6v-headlights/p1
dholck said:Not sure if this offers anything significantly different or better; these guys have bulbs that work on 6 or 12 volt, generator or alternator, etc. I have a pair, but have not put them on the car yet. http://www.logolites.com/products/led-headlights/
50C8DAN said:There are several threads on this.
I did lighting system upgrades for the Automotive industry, and have been in almost every plant in North America. I just wanted to share some of that knowledge for the benefit of others on the board.
ratlee2 said:I have used the Rampage conversion on my Jeep Wrangler. They are 12 volt, but it was a huge improvement over the seal beam lights.
I have 6 volt q-h bulbs in my 1928 Essex, with a 45 amp generator and relay. they are incredibly good.0
I don’t see any comments about working on a stock 6 V Positive ground system.Do they ? Thanks0
supersix said:I don’t see any comments about working on a stock 6 V Positive ground system.Do they ? Thanks
If you want 6v led positive etc light bulbs for all lights front and rear use these guys www.classicandvintagebulbs.com0
I'm running the LED's (headlites , taillights and dash lites) in my '37. All six volt pos. ground, and all fit in the original type sockets. A good lighting improvement! Here's where I bought them: http://www.dynamoregulatorconversions.com/online-shop-for-led-bulbs-and-light-boards-etc.php
ken1962 said:If you want 6v led positive etc light bulbs for all lights front and rear use these guys www.classicandvintagebulbs.com
I've been restoring old car hobby since '73. Before there were all these one stop shop resellers, we had to figure out what part we needed and then find a source for it or something similar. For example, I can get seals from Roger Zatkoff seals and Packings in Detroit. I still use that approach.
Since LED's are almost exclusive to China, and I'm the parsimonious sort when it comes to restoration work, I'm going to work up a bill of materials for LED replacement lamps at a lower cost than a one stop shop. Conversion kits can cost over $100 for headlights, yet a little research yields a setup for less than $60.
I really want to get bright rear lamps for the small glass tail lights for safety's sake, and then sort out the blinker adaptor relay. It's been solved for other vehicles, so it shouldn't be difficult to adapt to a Hudson.
Finally, I want a bright light for the Hudson emblem in the grille! I LOVE that feature, and I want it to stand out when it's lit. LED's generate a third of the heat of an incandescent, so it can be much brighter without damaging the plastic.
Just a note. Some countries have rules about aftermarket LED conversion kits. Im thinking it might be the places that are RHD ( so potentially a third of the world). Near all the aftermarket kits are made for LHD systems that have a different spread/light pattern. Here in NZ they are now unfortunately illegal so those of use who are wanting to upgrade are stuck with Halogen setups. Might pay to check your countries regulations before undergoing the upgrade.
One option for us RHD people is Hella or similar brands who cover RHD lenses.
https://www.hella.co.nz/en/products/driving-headlamp/7-round-headlamps-and-housings/
Lenses are made for RHD. By this i mean when you dim the lights etc the light pattern will point to the side of the road and not to the center/into on coming drivers eyes like they would if you used LHD lenses.
Note if you are looking at the above Hella link and the "chrome" ring then note they are plastic. - I wasnt amused when mine arrived and returned them. The stock Hudsons fit fine to aftermarket Hela buckets though.
Also dont forget to use Relays.
Chuck if the old eyesight is a bit underpar to read a manual then try a TV/projector/laptop in the garage hooked up to a chromecast. Makes life easy to have it on bigscreen to glance up at as you work at the car. also has the benefit of being able to just search what you are after - no matter if its the car manual, google or youtube.
thanks for the thread - also a number of really good ones if you search as well.0 -
It is very interesting indeed. Do someone know if LEDLight.com does shipping worldwide? If not, is there another automotive lights company that does it ?0
KustomKreeps,
the link thatJon B gives above is from the RHD driving U.K. So hopefully........
- 103 Hudson 1916 - 1929
- 90 Essex Super 6
- 28.5K HUDSON
- 558 "How To" - Skills, mechanical and other wise
- 992 Street Rods
- 172 The Flathead Forum
- 77 Hudson 8
- 597 Vehicles
