Fly wheel
Fly wheel is the same Ron0
Thanks Ron0
Yes and no! If your car is an 8 cylinder then the clutch is the same. If a 6 cyl, then clutch is too small to handle an overdrive. Flywheels are different for 9" and 10" clutches, and you need the 10" unit for overdrive.0
Thank you Geoff0
