'36 Terraplane Wiring in the Engine Bay
I'm trying to determine the original factory routing of the headlight and horn armored wiring, as it runs from the driver side of the engine bay over to the passenger side. I have the original harness, but when I bought the car, those armored cables were laying loose atop the frame crossmember just behind the radiator. Can't imagine that being anywhere close to being right. But so far I have not found any attach points for harness clips, so I was hoping someone might have a photo of how the cables are run and secured.
Thanks!
Tom
your wiring harness goes from the drivers side to the passenger side under the radiator check the drivers side to see were the horn and headlight wires exit through the inner fender well it should be the same on each side I believe there are clips on the sides and the bottom of the radiator mounting bracket for holding the wire harness in place I hope this helps.
