Early stepdown pinion seal
boothguy
boothguy Senior Contributor
The only number I can find on the net is National 47331. Can someone confirm this as correct for '49 Thanks
  • Geoff
    Geoff Senior Contributor
    The numbers I have are National 6487 or CR17177. The specs are O/D 3.066, I/D 1.713
    Geoff.
  • My National catalog lists the following for pinion seal: 50812 1948 w/cone type dirt shield. 50757 1948-49 w/flat dirt shield. And 6487 for 1950-52. And 5778 for 1953 incl Jet. My catalog listings stop at 1953. Gert
  • boothguy
    Are all these readily available? I didn't want to pull the seal to check for a number if its going to take awhile to get.
    Call Dave Kostansek, Williamsfield Motors, Number is in the classified section of The WTN or do a search on this forum. I just bought one for my '52, he had them in stock. You could also check with Dale Cooper or Bill albright.
  • boothguy
    I did a search on the forum and also Ken Cates and Dave Sollons sites and that was the only number I came up with which was for a 51. I was hoping to do the job today while I have access to a lift if the seal is commonly available
  • shadetree
    shadetree Senior Contributor
    take the measurements as per Geoff to your local parts house and he should be able to pull a replacement off the shelve, better than the old spring, leather original, it worked for me. a few years back. Melvin
