8 cyl. compression
hudsonsplasher1
Hi all,
What is a normal compression for a healthy straight 8?
Thanks in advance.
Gene.
Thanks in advance.
Gene.
hudsonsplasher1 said:Hi all,
What is a normal compression for a healthy 49 straight 8?
Thanks in advance.
Gene.
Anything between 85-110, with a hot motor, and they should all be around the same.0
Thanks Geoff.Geoff said:Anything between 85-110, with a hot motor, and they should all be around the same.0
