Needed a good running, rebuilt or rebuildable 308.
                    Senior
                    Needed: a good running, or rebuildable 308. We found out our 308 Has some cracks between #3 and 4 cylinders. Can these be fixed? If not we are in need of a good 308 Block but would also consider a whole engine. Any ideas? Thanks for the help in advance. Also need a radiator and non-cracked exhaust manifold.
            Check with Doug Wildrick. The machine shop he uses repairs the manifolds.Perkins Repair Service does cast iron welding repair and machining. Fairland In 317-847-7446Also-
            I have several 308 blocks Some are skeleton blocks other not so. Where are you located?0
            Lance what you got in 308`s......where you at ?....me near Pensacola Fl.0
            Location is N.C. I have 308's in as is and skeleton configurations.0
            Are u a business ? Can I call you ?0
            704 791 911zero0
            I`m gonna look hard around here closer to home...if not..i got u number...Thanks ! !0
- 111 Hudson 1916 - 1929
- 177 The Flathead Forum
