34 Terraplane headlight
tomt
I am looking for a few headlight lens retainers for a 34 Terraplane these are the type that fit through a spring and clip into the bucket. I would prefer new.
Thanks for any help.
Tom
Donald Axelrod of Massachusetts sells complete headlights only, but you might try him anyway. Possibly he has a broken or "parts headlight" with the clips you need, that he'd sell you. Here's the contact info that I have for him:
Donald I. Axelrod
35 Timson St.
Lynn, MA 01902
781-598-0523
Thanks much, I will contact Donald.
Donald Axelrod does have these parts, contact him at the above phone # or hdlthqtrs@aol.com
I need to restore my 35H headlights in the near future. So I looked at the clips wanted. I dont have spares but this is what they look like. A simple clip that slides up between the 2 fingers.
Would require some effort but certainly look to be something one could make since you have a pattern0
The Terraplane is different than the picture. Old Fogey described them, an arrow shaped clip that goes through a spring and into a bracket in the bucket. The clips need to be turned 90 degrees to fit into the bracket, and then turned back. Same to remove them.
Received them from David Axelrod, and have them installed. Thanks for the help.
Have just learnt that my photos are of 1934 and not 1935 headlight0
