Steps for installing cork clutch.
Rob Fayette
Does the new cork clutch from Doug Wildrick have to be soaked before it's installed. If so, what do you soak it in, and for how long?
Thanks,
Rob
Thanks,
Rob
Shouldn't need soaking, but a wash-over with clutch fluid before installing will ensure that it does not stick to the surface of the flywheel or pressure plate.0
Thanks Geoff. I will do that.
Rob0
