Door problem
It had been while so I took the door key and locked the driver side door to my Stepdown. After that I couldn't get the door to open, even though the door knob was pulled up. The key would push and pull the interior knob, but the interior handle nor the door handle button would open the door. I had to use a homemade "slim jim" to get it opened. Now the pin that goes into the door latch won't move and the outside button and interior handle still don't work. I sure would like to know if I can fix this without taking the door panels off...
I think your going to have to take if off sounds like the clip that holds the rod came off the outside door handle0
I'm afraid you're right.0
Let me know if you need any help Jason.0
Hello,
Not trying to hijack this thread, but I was wondering in what year Hudson changed from pulling the inside knob up to lock the door, to pushing it down to lock the door? I think it was pull up to lock through at least 1947.
Thank you, and take care,
Steve Bryson0 -
I took off the garnish moulding and the interior handles off. Are there instructions in one of the repair manuals that tells how to get the rest of things mentioned in this post out?Ken U-Tx said:And yes you can bet your sweet patooty that you will have to remove the garnish moulding. , the interior handles, the vent window assembly, the roll down glass, the rear part of the felt channel, and the lower metal channel that felt channel fits in before you can even get the door lock assembly out. Loads of fun!0 -
The body Service Manual covers this topic. Page 60
Don't need a service manual if you have Lance Walker living just 65 miles away. This guy drove to my house and brought a replacement door latch (plus a ring gear I need) with him. To top that off, he installed it for me within 20 minutes. You don't find friends like that every day.0
DOGWOOD CHAPTER CAMARADERIE !!!0
That’s the difference between a HET guy and a lot of others .They come by say yep it’s broke drink your last beer and leave0
