Splasher 6 oil pressure swtch
Just dismantle and clean.0
How did you remove the frozen plunger? I may need to use heat.0
You can try brake kleen spray it real good0
block off the outlet, remove the cap and the bottom elbow fit a grease nipple and put your grease gun on it.0
This fall I used Liquid Wrench to free a stuck (rusted) straight 8 engine after reading about it being better than others in a test trial. Within 3 days I had the 3 problem cylinders freed up & engine turning. So you may try it, but if nothing is working turn to heat. I have a small propane torch I used on some stuck brake lines just this week. Best of luck!0
Heat will destroy the bakelite plug that the contact pin is embedded in.0
Might try soaking in some evapo rust. Good stuff!
- 175 The Flathead Forum
- 602 Vehicles
