Oil pressure Gauge
Hello
Is there anyway to hook up a oil pressure gauge to a straight 8? I see no provisions on the block
There is no need. If you did you would only get around 5 lbs. registering. The oil pump simply lifts the oil from the sump to the crankcase. If the light goes out, the pump is working.0
