Radial tires stepdown
I have 235/75 Coker www radials on my '53. They DO NOT RUB AT ALL AND NEVER HAVE. Maybe if someone didn't have a Panhard rod at the rear they might there.
However, I do not recommend you go that size. Suggest 215 or 225. My tires were on the car when I got it.
NOTE: I believe the 235/70/15 would rub at rear.
The 235s will NOT fit down in the spare tire recess.
I also recommend you use Diamond Back and NOT Coker.
I have power steering so I do not know if 235s might steer 'heavy' with manual; but to me: any stepdown w/o power steering is a handful !! But I am OLD ~~~0 -
Thank you0
I might go with the BF Goodrich Silvertown Whitewall radials0
A 215/75-15 is close to the 7.10-15 and a 225/75-15 is close to the 7.60-15 and also the H-78-15.0
