overdrive on a toggle
Can anyone shed light on wiring my overdrive to work from a toggle switch?
thanks mucho
hot to fuse, then to toggle switch. toggle to large terminal on overdrive solenoid.
Recommend using a relay to supply battery power to relay. in that case wire in relay to battery power and use toggle to actuate relay wired to overdrive solenoid.
have this setup on all my cars.
So that bypasses everything correct? and when I want it to come out of overdrive I just shut the toggle off ?0
So does that take the governor out of the equation I'm really not sure how the overdrive works because I haven't started it yet I'm sure it's not that complicated but I'm just looking for the simplest solution0
Also remember that you can't put the car in reverse unless the overdrive is toggled off. If you leave the overdrive in while at a red light, you will be starting out in second gear. I had this setup on mine as well.
Interesting. I actually have my OD kickdown wired to a momentary-contact pushbutton switch mounted beneath the dash (as opposed to a toggle switch). So, whenever I need to downshift to third gear, I depress the button while releasing the gas momentarily.
For many years I had a plunger kickdown switch mounted under the accelerator and it worked fine, but some time ago the car started backfiring whenever I would push the gas pedal to the floor. (No idea why that was happening). So I re-wired the circuit to incorporate the pushbutton, and no more backfire.0 -
When you say "backfiring", what is actually happening is that the unburnt mixture that is sent into the exhaust, for the power strokes that are shorted out, are igniting and exploding out the exhaust pipe.0
Agreed, Geoff. But I wonder why this began to happen all of a sudden, after almost 40 years of working fine? One possibility is that I changed to a much heavier transmission oil (140 weight, I recall). I wonder if that got into the solenoid and made the rod move in and out slower, thus causing the delay in the "momentary" shorting of the ignition. Because the ignition paused so long, the gas built up in the exhaust pipe. Then when the ignition was finally restored....bang! I have just switched back to a modern, lightweight transmission oil (it's so thin that the gears clash every time I shift) but I haven't restored the pedal-activated kickdown switch yet, to see if the kickdown no longer causes backfire.
UPDATE: I restored the gas pedal kickdown switch, and the OD works like a charm. No more backfiring. I can only think it's because I'm now back a modern, lightweight oil in the transmission, so that the solenoid plunger no longer sticks (and thus there is no delay in the shorting of the ignition).
(I apologize for hijacking the threat, briefly! Just disregard me!)
Alan, is the toggle switch spring-loaded, or does it remain in the "on" position until you flick it back the other way?0 -
So the solenoid always has to be energized or needs a constant 12 volts going to it in order to stay in od ?0
Yes, or 6 volts if original. The solenoid has two coils, a heavy one for the pull-in, and light one for the hold in. Once the relay is activated the solenoid pulls in, and a pair of contacts internally opens the circuit to the pull-in, and closes it for the hold-in.0
what the heck am I thinking? 12 volts
It's tough getting old
okay I appreciate all the help0 -
works like a charm!!
I used a headlight relay and ran the ground terminal to a motor cycle toggle located on the sifter handle and the wire from the toggle to ground. The relay is activated when the ignition switch is turned on. I've been using this set up on my 46 Brougham since 1984. I have a Stude truck wired the same way except I wired the governor into the system so at low speeds the governor cuts out the overdrive and that solves the reverse problem. I've been using this set up since 1996. Split shifting the gears is fun.0
- 994 Street Rods
- 174 The Flathead Forum
- 602 Vehicles
