Filling rear end 1923 Hudson Super 6
Does anyone know the purpose of the extra fitting on my differential? I see the plug to fill and the plug to empty but what is the purpose of the other arm and
plug. The only thing I can think of is it is a way to measure the about of fluid you put in not to exceed this level? Anyone know the answer?
plug. The only thing I can think of is it is a way to measure the about of fluid you put in not to exceed this level? Anyone know the answer?Robert
It is actually a sight hole for aligning the mesh of the crown wheel and pinion.0
wow I never would have known that. What do modern cars have to do the same thing?Robert0
Modern cars are all pre-loaded and not adjustable the same. the principle is the same but the construction totally different.0
I'm confused.....it has a right angle bend I would think you couldn't see anything?Robert0
We are talking about the small square plug in the centre of the pinion housing, not the curved filler fitting.0
I'd say the elbow fitting is the filler and the top plug is the sight hole. The top of the elbow would be the limit for the amount of oil that can go in the diff, to drain the diff turn the elbow 180°.0
The elbow stays where it is. The drain plug is on the bottom of the diff.0
Thanks guys for straightening me out. I got it now. No telling what I will find when I drain it. I have the 600 wt steam oil to fill it with.Robert0
- 111 Hudson 1916 - 1929
