Flywheel
I am trying to locate the minimum thickness for a 10 inch flywheel on my 55, 308 engine
Is this a 55 flywheel and crankshaft?0
No picture!0
Yes it is a confirmed 55, 308 crate engine with hydraulic lifters. The flywheel is an oil filled design. I talked to Wildrick on this matter. they mic-ed a flywheel that they have. There's is .428 in thickness. My flywheel is .597 in thickness.
AMC manufactured a dry clutch setup for the 308 backed by a 3 spd OD transmission. Put this into the 55 cars.0
where do i find that flywheel?0
i would like that clutch in my car0
Check with the parts vendors of HET Parts.
There is a list on my website
https://hudsonrestoration1948-54.com
which one is your site? will 2 inch intake valves and 1.687 exhaust valves fit into my 308? I'm putting in hardened seats. the stock valves are 1.847 intake and 1.593 exhaust in my engine
My website is: https://hudsonrestoration1948-54.com
check out the Engine section for the information on 7X engine conversions0 -
thanks
You can get the valves from Randy Maas. I highly recommend his modern timing chain set as well.blondwookie said:which one is your site? will 2 inch intake valves and 1.687 exhaust valves fit into my 308? I'm putting in hardened seats. the stock valves are 1.847 intake and 1.593 exhaust in my engine0
- 112 Hudson 1916 - 1929
