Flywheel
I am trying to locate the minimum thickness for a 10 inch flywheel on my 55, 308 engine
  • Is this a 55 flywheel and crankshaft?
  • No picture!
  • Yes it is a confirmed 55, 308 crate engine with hydraulic lifters. The flywheel is an oil filled design. I talked to Wildrick on this matter. they mic-ed a flywheel that they have. There's is .428 in thickness. My flywheel is .597 in thickness.
  • AMC manufactured a dry clutch setup for the 308 backed by a 3 spd OD transmission. Put this into the 55 cars.
  • where do i find that flywheel?
  • i would like that clutch in my car
  • Check with the parts vendors of HET Parts.
    There is a list on my website
    https://hudsonrestoration1948-54.com
  • which one is your site? will 2 inch intake valves and 1.687 exhaust valves fit into my 308? I'm putting in hardened seats. the stock valves are 1.847 intake and 1.593 exhaust in my engine
  • My website is: https://hudsonrestoration1948-54.com
    check out the Engine section for the information on 7X engine conversions
    You can get the valves from Randy Maas. I highly recommend his modern timing chain set as well.
