Starter Question
Only if you space it out half an inch. The ring gear is a different spacing from the pinion longitudinally .0
What about using a hydro starter on a manual step down car?0
The hydro starter is smaller in diameter than the stickshift starter, where it indexes into the rear engine plate.cheyenne7271 said:What about using a hydro starter on a manual step down car?0 -
Ok thank you0
Thanks Geoff0
The automatic transmission starter is completely different, and engages from the front, not the rear.0
