Rear end gear ratio
hudsonsplasher1
Looking for opinion on 4-10 rear end with overdrive. Is this a good combo or would a higher gear work better?
Depends on what model you are talking about. Works just fine in my Jet.0
4:10 was perfect on my 49 with Hornet power. With your 8, will not win any stop light races but will be great on the ex way.0
Ric West IN said:4:10 was perfect on my 49 with Hornet power. With your 8, will not win any stop light races but will be great on the ex way.0
Depends on your terrain. Here in the Adirondacks, My Commadore with OD works better with the 4:56. If you're mostly flat, a 4:11 would work OK with OD. My truck has a 212, standard with 4:11 and 16 inch tires and that works good for hauling
. I had a standard Hornet, no OD with a 3:58. Nice combo.
Uncle Josh said:Depends on your terrain. Here in the Adirondacks, My Commadore with OD works better with the 4:56. If you're mostly flat, a 4:11 would work OK with OD. My truck has a 212, standard with 4:11 and 16 inch tires and that works good for hauling
I had a 49 Commodore with 262 , OD and 4:10 , was great except in Pennsylvania mountains, some of the long climbs lost speed , had to kick down to maintain speed and stop spark knock.. In Ohio I had no problems, good mileage , around 20 mpg.
I wish my Super 6 w OD and 4.11s would get better than 15mpg, runs perfect otherwise0
Thanks everyone for your input.0
cheyenne7271 said:I wish my Super 6 w OD and 4.11s would get better than 15mpg, runs perfect otherwise Timing may be a little late
Josh I checked at the time I got it running last year and it was dead on, don’t have any ping. Possibly the vac advance is not working.0
- 173 The Flathead Forum
- 599 Vehicles
