Master cylinder rebuilding kit
Found these numbers:
Dorman- TM3502
NAPA- UP2
O’Reilly’s- MCK35020 -
Can one use the fittings off of the old master cylinder?
I Echo the comments to Buy a NEW Master Cyl, Don't hone that old one... Therev on Ebay often too....
Consider insulating the brake line near the exhaust pipe0
I did buy a new master cylinder, NAPA M4360 a little while ago. I’ve yet to take the original master cylinder apart to even know the condition. I still find it cool as all heck seeing “LOCKHEED” stamped on it & wheel cylinders.... definitely space age technology in 37!Ken, What is the banjo bolt for or where is it located? If I need the “Y” block, etc, what do you ask for them?
Thanks everyone!0 -
Here is photo of fitting and banjo( from Ken)
- 112 Hudson 1916 - 1929
