Heater help
Hi everybody! I need some advice regarding the heater motor from my '51 Pacemaker. I took the housing to be powder coated, and while it's gone I decided to open
the motor to see if I could replace the old steel wiring. I have two problems: The set screw that holds the fan assembly to the motor is rusted tight. There is not enough space to fit a pair of pliers and apply any torque, and despite several applications of WD40 I can't turn the screw. The second problem is that I tried to loosen the two nuts that hold the motor together from the bottom. While turning the first nut I heard a "snap" and I assume the bolt broke, but I can't pull it out.
I'm afraid I'm in over my head. Is there anyone that works on these or should I look for a replacement?
Thanks!
Thanks!
Lance to the white courtesy phone please!
Get some plastersence and form a well around the screw. Wd40 will not work. It's a lubricant only. Use penetranting oil spray instead. Fill the well with it and it should work into the joint after a day or too.0
LOL Thanks John. I have the fans, motors and parts for these. Let me know if you need anything. The set screws are a real joy so when I replace them I usually use allen head set screws. Sometimes a little bit of hotwrench will cure the problem.0
- 115 Hudson 1916 - 1929
